enlarging text possible in plugin?
rhurbarb
In webcamviewer, i would like to enlarge the list when opened so that i can see the full name of the shortcut, currently the box is too small, love to sort this annoying problem for me out. Thanks
Then you would have to change plugin coding .
Or ask the author to do it.
Who is the author I do not know.
Thanks Matrix, i did go into theWebcamViewConfig.pyo file <screen position="100,100" size="650,500" title="Setup" > and increased the 650 and 500 by 10 percent, but the plugin did not show in the list after i rebooted .
Would you recommend where i would start to try and fight the Author if anybody else can`t help?
fight, lol i ment find sorry
And do i need plugin editor instead of notepad /notepad++
the code looks strange in the pyo file as if its encypted
cheers
Thanks very much Nunigaia, Il open an issue right now , must say you guys are very helpfull, quick at replies and that makes this forum the best !..
This problem has persuaded me to look at Python programming. Cheers Matrix and Nunigaia
