Hi. I have a VU+ Duo2 with dual S2 and dual T2. Loving the box especially how quick it is to operate. However, not much use until I can sort the EPG so I can record stuff for the mrs
1- On alot of the Freeview channels the epg is gibberish text like & - |(@ though sometimes I noticed it corrects itself when on the channel? Any ideas on fixing this in the EPG? I'm guessing its data within the dvb-t2 signal? Or will this not be an issue with correct internet epg set up? I can't tell what data source the epg is using. I think I've used CrossEPG to setup OpenEPG for SlyUK and guess this doesn't touch freeview programs? Do I use a Rytek UK for freeview? I also saw in the original VU image something about autobouquets and only showing FTA channels but not in BH. Some channels like More4 HD show black screen and double press OK shows info with "ND" in red which I assume means not decrypted but it's Freeview channel in this case. Same for QVC Beauty HD which does not show ND? There are no default service lists in the menu setting so maybe I need the Default Service Scanner extension?
2- should I use a swapfile? Currently set to none.
3- any reason to have swapfile, picons on usb stick?
4- does deep standby lose any functionality other than turn of LCD, maybe slower turn on and possibly stop remote access/streaming?
5- does Web interface plugin have any advantages over whats offered via OpenWebif web access?
6- OpenWebif works great, but if set http authentication on and/or https authentication where do I set the login details? Also, how many remote users can access? Seems to be the one port?
7- my ealier post of disk initialisation was solved with BH update and skin update. Don't know if related, but I have no mount points showing which I'm sure I did for the drive (I re-initialised after switching to BH image)
8- is there a way to have a last channel button?
Hope these queries can be quickly answered by a pro. I'm an IT person but new to sat enigma2 box. Main thing is to get a good epg running so I can be recording stuff. I pressume its best to have an epg/bouqet/fav and separate sat and freeview channels for recording purposes? I have seen other epg plugins that look nice but how would i set with one is used/default?
Thanks for reading and any help you can provide
