EPG and timer issues
Simplyme
Since my last problem in September last year I have managed to reset my Vu+ Solo2 with two satellite feeds, both 28.2E and the recording problems disappeared. I am operating with Blackhole 2.0.6.3 and have been using a Rytec EPG downloaded to an internal HDD on a daily basis. I have been recording individual programmes and weekly episodes of series using the timer without much of a problem until March this year. It was then that I started having problems with the EPG and the timer recording – the timing may be coincidental but I suspect they are linked.
First of all, the EPG stopped downloading on a daily basis. I consulted the forum and discovered that others were having similar problems, so I switched to a crossepg provider, which did the trick for a while. At about the same time, some of the programmes I had set to record only recorded a blank screen and the information on the recording as to time and duration was all to cock. Since then I have had persistent problems with EPG daily downloads and have been downloading manually, using the yellow button. My success with these has become more and more inconsistent and I have noticed that every time I download an EPG, I appear to lose the effectiveness of the timer recording facility. That is to say, the timer event is still listed in the Timer Menu and the programme remains marked in the EPG but not brightly highlighted and the recoding comes out as a blank screen. I have had no choice but to delete the original timer event and re-input the timer recording details. This is becoming extremely tedious.
Over the last two weeks I have consulted various themes on the forum and having deleted EPGdat files and tried XMLTV and XEPGDB providers (none of which work on a daily basis), I have managed to get an OpenTV provider to work on a daily download. However, this has not solved the timer recording issue. I still lose the effectiveness of timer recording after both manual and automatic downloads of the EPG. For the time being I have decided to manually download the EPG once or twice a week and redo the timed events each time. I would be very grateful if someone could point me towards a solution.
As I had not received any replies to my post, I decided to take some positive but drastic action. First of all I flashed a new version of Blackhole(2.0.9) and on the third attempt got it to load OK. It made no difference – timer recordings appear to be disabled after each EPG update (manual or automatic). So I decided to be even more drastic and did a factory reset, re-flashed Blackhole 2.0.9 and loaded new versions of TS Panel, *****, bouquets, Cross EPG and reconfigured the satellite feeds and set up the channels. All the methods of EPG downloads work but I still have the timer recording issue.
Once I set a timer event, it works and repeats itself as long as the EPG is not updated. As soon as there is an update, the timer event still shows but the marker next to the programme in the EPG is “dimmed”. If the recording takes place in this condition, the recording is listed but with no time duration shown and when played, shows a black screen for a while and then stops with an “end” message.
I have continued to do further research on this but cannot find many references. One I looked at mentioned a file (lib/opkg/lists) becoming overfull but this was in relation to VIX set up and anyway my file was empty.
I have now exhausted the areas I can tackle and I am desperate for some advice on how to proceed.
In this board is not admitted any reference to emus.
You are been banned for a week and this thread closed.
