EPG for current program on 1.4.1
Jotne
When I like to see EPG fro current channels, I always has pressed info button, and get the info.
With this image I do get 3 option (Simple EPG/Grapich Multi EPG etc.)
I then have to select one of them and then select the program I look at.
How to convert this back so I get EPG info for current channels in one click?
If you press epg botton you should see epg of current channel.
While with long press of epg botton you sholud be able to choose multiepg or other epg.
Try and let me know.
Ahh
It works, but my Pronto NG Pro remote do not support long press.
Do you know where I can change/swap long press "l" and short press "b"
I have done some equal before on blue button, but do not remember.
Ahh
You mean how to program your RC?
Why don't you use the original one?
I like one good control instead of 10 (TV/VU+/Amplefier/BlueRayplayer etc etc) :)
I see that in 1.42 you have relpaced long/short press EPG
Thank you
