EPG in IPTV
p.rodrigues
Is there any way to load the EPG into a client box that uses another one via IPTV? Here I have a situation of a Duo 4K as a customer of a Uno 4K SE, on IPTV, on a given channel ...
Yes, Falbacktuner does this but, being a specific situation and not wanting to use this function, is there any way to achieve this?
Someone recommended WebGrab for this ... how does it work?
Example of IPTV channel in the client box (it is an FTA channel):
M.R.SOTO
Si se puede ...
Con dreambox editas el canal de IPTV.
Marca DVB/TS y después configuras las casillas en DVB/TS data igual que tengas el canal en SAT y así coge el epg y el picón...
p.rodrigues
Si se puede ...
Unsuccessful, perhaps because the IPTV comes from Uno 4K SE ... the picon is recognized.
