EPG Issue
Tony Heaton
Hi guys
I have a VU+ Duo running BH image. I had the full 7day epg working up until last weekend.
I upgraged the image on monday and now I can't get the EPG to work
I use Cool tvguide and Crossepg downloader
the standard EPG does not work either.
Any suggestions?
Im not using Crossepg
Im using our image EPG system.
Direct download Rytec EPG works without problems
The problem is that now you have to be on a channel from the bouquets/favourites
in order to have the EPG.
I have test with Rytec SKY.IT EPG download and with Rytec-BE-NL-SKYUK download.
I do not know at this point whether is this change in CVS or not.
I will ask the coder
So download EPG with our image EPG
and go to a channel and you will have the EPG.
146 Bh,Open epg in my duo on the channel marcopolo or NGC .. pop up notifications not is visible and epg not loading.
On bh 145 is all ok.
Is an only my problem?
Have you enabled the OpenETV EPG Loader via Blue -> Red button ?
