reboot and test again CrossEPG
============================ Of course, this will only help if you have not installed these python files.
If you already have ,then problem is somewhere else.
And where I do not know.
You have to config storage device HDD or USB in crossEPG>>>Configure
(here you can also config Scheduled download)
You have to download or config provideres for witch you like to have EPG
>>>XMLTV providers (direct download or config provider/s for download)
you can also use download now in CrossEPG Menu to download epg from provider/s
you have config in XMLTV providers e..t.c
If not working try to delete old epg files in
/media/hdd/crossepg/delete files here
or
/media/usb/crossepg/delete files here
CrossEPG on my Solo 4K does not work anymore, the network is OK so I do not know what's wrong
Are there any more who have problems with CrossEPG or just me, this does not work
@Matrix10
What are the Rytec srttings ( providers) to download, Poland channel,13E, German Sky , 19E and Spain movistar 19E?
There are so many rytec providers, i don't know which are
Hi guys, on vu+ solo SE with blackhole 3.0.5 .K I'm using CrossEPG. I already selected the providers (italy basis, sk*, sports..) and they are correctly downloaded in the crossepg folder inside the correctly mounted hard disk. Even if I already know it was not necessary via telnet I wrote the 2 commands: opkg install python-pkgutil and opkg install xz. But nothing to do I don't see any epg running. Anybody can help me?
