epg problem! & built in fix for rats channel updater
wrighty998
hi all
blackhole has worked well for me but after the update over to 2.0.3 i cannot get my epg to refresh on its own Ive tried everything disable all options in epg panel add all options in epg panel but still no joy i use crossepg to download my 7 days listing and so far the ONLY way i can have the epg refreshed is to restart the box then it will come back on with 7 days if any one can help with this i would be very happy
on a 2nd note a month ago i reveled (on this site) the only way you could get rats channel list plugin to work on black hole and was hoping this would be built into the latest update but after updating i had to do it again all it is is adding a small line to the bottom of a file is this impossible to have bulit in?? this is what need to be done
"ftp to you box...got to folder "var"...then "etc".....then "opkg"....then right click on the "opkg.confg" file and edit it with notepad by adding the line "arch mipsel 100"....right at the bottom.....exit and save...now you can install any .ipk package"
thanks to all who can help
p.s i don't want to sound like im complaining i appreciate all work done and im just trying to help make blackhole even better for the community :)
hi all
I can answer to the second point: NO. The Opkg image files are built during compilie image process and customize them can be very problematic for future releases to make full compatibility with Vu+ code.
thanks pal i understand now just hope someone can help with the 1st problem
