EPG Problem
prosit
I've noticed is that the EPG on channel choice is not displayed correctly
What are the reasons?
I've tried BH 1.7.3 and 1.7.4
Best regards
Yes, the provider is Platforma HD
Then update the epg provider list,,,it may solve the issue!
Or use CrossEpg plugin it has several providers and data is better organized (not recommended for Vu Duo)!
In conclusion, this bug/issue, has nothing to do with BH image or Skins!
.....In conclusion, this bug/issue, has nothing to do with BH image or Skins!
Yes, by the way, I've tried with Black Pole ...
With Black Pole is all right.
That means for me that is this bugs associated with BlackHole.
In addition I have looked Event Name and Event Source.....
In BP and BH they are different.
Why?........
Why?........
I have no idea...:wallbash:!
So, what EPG plugin to use with VU+ Duo if CrossEpg is not recommended?
CrossEpg is installed by default with BH image!
Yes,Its there,,,but you can deactivated or disable it !
With Duo its the Ram memory issue, the new Duo, coming soon, will be far better with more RAM memory!
So for now,I use OpenTV epg & Rytec ...the BH original built in EPG!
Plus 32 swap file on USB and e2-forceream 0.1 ,to force SWAP to reduce RAM of Vu+ Duo (by linuxsat)
I have a Duo and also have problems with the EPG.
Where to disable CrossEPG? Is it by disabling scheduled download in the config?
I think everyones having smaller or bigger problems with crossepg.Vu duo haven't got enough memory.Got worse when installed couple extra plugins
I think croossepg work good when is setup 2-3 provider no more i have only polish italy epg setup and all work good. Please write epg is usb ...
At a minute I have 5 epg providers setup.And that setup seems to work o.k But couple any extra plugins makes my duo life difficult
