Its a common fault, with no fixes to it as far as i know, ive had this problem for over a year and have still not found the fix. Thought blackhole would have fixed it this new image but there havent.
The only bug I know when using Crossepg is if you have 2 partitions on usb key, eg /universe on the first and /usb on the second, and you enter in setup menu of cross epg without modifying anything, the epg will be stored in the first partition instead of the second.
The bug is probably into crossepg and not in BlackHole.
