EPG showing only current and next event
Yannis.21
I apologize upfront if am in a wrong thread, it made sense to post my problem here as it is focusing on an EPG problem.
After making a clean install of BH v1.7.8 I have this weird problem.
Both CoolTVGuide and the Graphical EPG only show (correctly) current and next events. I deleted the epg.dat file from USB, loaded previous CoolTVGuide versions, added / removed EPG refresh, always the same result, epg shows only current and next event. In EPG Panel all settings are OK, epg is looking at the usb, the usb is mounted correctly, manual downloads do not solve the problem, epg always showing only current and next events.
I am sure that with previous version (not sure if this is an image issue anyway or probably something screwed) I had several days ahead of epg data which for me is essential as I do a lot of programming through timers.
Any help extremely appreciated, starting to drive me crazy...
Yannis
Sorry for the fuss, I re-flashed the image again and somehow everything came back to normal and working as expected.
