EPG turkish characters
aligator638
Hello all,
I have an issue, here in Turkey, the EPG on the webif will not show Turkish special characters correctly, as in the picture below.
I use BH 2.1.2 on a Duo2.
Any idea on how this fix this ?
Thanks,
Eric
I haven't tested but maybe you can try EPG Türkçe Karakter Düzeltme Plugini
( Epg Turkish character fix plugin )
Hello Livi,
Thanks for your input. I had a look at this plugin that is part of another tool. It is used to copy EPG data between chanels. As part of this the EPG data is converted.
My whole feeling about this, is this is a well know know issue with codepages.
This should be fixed by the blackhole dev team.
Eric
