Error access ftp and telnet
allu
I have a problem with my Vu + Solo2
Until yesterday I had no problems and the BH 2.0.6 C
Yesterday upgrade to BH 2.0.9.1 and every 2-3 hours can not access the VU via ftp or telnet, but I can by web
If I go by web and reboot my VU, I re-enter ftp and telnet until 2-3 hours fails again
Write in your Mother Language for now and be more specific in what conditions you have problems. I'll use translator to understand what is your problem and I'll translate for others.
Buenas tardes
Desde hace tiempo tenia mi vu+ solo2 con la imagen BH2.0.6C en flash con IP Fija. El Vu+ va fenomenal y no tenia ningun tipo de problema
Al ver que habia salido la BH 2.0.9 decidi actualizarlo
Instale la BH 2.0.9 desde cero, es decir, sin restaurar los setings, configurando todo desde el principio
El problema que tengo es que el Vu va muy lento. Por ejemplo, entro en Menu, y si quiero elegir una opcion, el Vu se queda como pensando, con el circulito azul arriba a la izquierda y al cabo de unos 5-6 segundos entra en ese menu. Si quiero ir a cualquier otro menu pasa lo mismo
Ademas, cuando pasan un par de horas de estar encendido, no puedo acceder desde mi ordenador (via LAN) ni por ftp ni por Telnet. Si reinicio el Vu, puedo volver a acceder, pero al cabo de otro par de horas vuelve a fallar
Google Translated and Edited by me:
@allu said:
Good afternoon
I've been using a long time vu + solo2 BH2.0.6C image in flash with Static IP. The Vu + was great and did not have any type of problem
Until I decided to upgrade to 2.0.9.
I installed the BH 2.0.9 from scratch, ie, without restoring setings, configuring everything from scratch
The problem I have is that the Vu+ is very slow now. For example, I go into Menu, and if I want to choose an option, the Vu freezes, with blue small circle top left (spinner running) and after about 5-6 seconds enter that menu. If I want to select any other menu it's the same.
Moreover, when it's on for a couple of hours, I can not access it from my computer (via LAN) or by ftp or by Telnet. Rebooting the Vu, I can acess, but after another couple of hours fails again.
I reinstaled BH 2.0.6-3 but problems with ftp and telnet continue
when it's on for a couple of hours, I can not access it from my computer (via LAN) or by ftp or by Telnet but i can access to openwebif. Rebooting the Vu, I can acess, but after another couple of hours fails again.
Check you router settings. Openwebif uses port 80, FTP 20 and Telnet 23. Could be some port/IP address "restriction" setting problem.
I have not touched anything in the router.
If I was a router problem, would not allow access from the first, but not when it's been a while
This weekend I will do more tests
Look what happened this afternoon:
16:15 Im flasing and reboot. I can access via ftp and telnet from the LAN and from the iPhone
16:34: I can access from the iPhone and from Lan
17:40 works the same as before
19:08 works the same as before
21:30 I can not access or ftp or telnet or from iPhone or from Lan. The Deco respond well Ping and goes to the Internet
Really do not understand :-(
Enviado desde mi ZX Spectrum 48K
