Error with original Makefile Kernel 3.1.1
lolly
Hey guys,
i have an Error with the original Makefile Kernel 3.1.1 on my second system (Debian squeeze).
Its no trouble for me, i have a another build system with Debian lenny but i will use in the future the new system.
The Error comes @ Last Task!
log_do_rootfs say this:
+ mkfs.ubifs -r /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/rootfs/vuplus-image -o /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.rootfs.ubifs -m 2048 -e 126976 -c 4096 -F
+ ubinize -o /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.rootfs.ubi -m 2048 -p 128KiB ubinize.cfg
ubinize: volume size was not specified in section "ubifs", assume minimum to fit image "/home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.rootfs.ubifs"81772544 bytes (78.0 MiB)
+ vfi3 /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.rootfs.ubi /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.boot.jffs2 /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.vmlinux.gz
/home/debian/Images/Vuplus3.1.1/bm750/build/tmp/work/bm750-oe-linux/vuplus-image-1.0-r0/temp/run.do_rootfs.626: line 697: /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/staging/x86_64-linux/usr/bin/vfi3: No such file or directory
run_do_rootfs say this:
cp /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/rootfs/vuplus-image/boot/vmlinux.gz /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.vmlinux.gz; rm -f /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/rootfs/vuplus-image/boot/vmlinux.gz; mkfs.jffs2 --root=/home/debian/Images/Vuplus3.1.1/bm750/build/tmp/rootfs/vuplus-image/boot --faketime --disable-compressor=lzo --compression-mode=size --output=/home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.boot.jffs2 --eraseblock=0x20000 -n -l ; rm -rf /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/rootfs/vuplus-image/boot/*; echo \[ubifs\] > ubinize.cfg ; echo mode=ubi >> ubinize.cfg ; echo image=/home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.rootfs.ubifs >> ubinize.cfg ; echo vol_id=0 >> ubinize.cfg ; echo vol_type=dynamic >> ubinize.cfg ; echo vol_name=rootfs >> ubinize.cfg ; echo vol_flags=autoresize >> ubinize.cfg;mkfs.ubifs -r /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/rootfs/vuplus-image -o /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.rootfs.ubifs -m 2048 -e 126976 -c 4096 -F && ubinize -o /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.rootfs.ubi -m 2048 -p 128KiB ubinize.cfg; vfi3 /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.rootfs.ubi /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.boot.jffs2 /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.vmlinux.gz > /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.nfi; mkdir -p /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus/duo; cp /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.rootfs.ubi /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus/duo/root_cfe_auto.jffs2; cp /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.boot.jffs2 /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus/duo/boot_cfe_auto.jffs2; cp /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.vmlinux.gz /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus/duo/kernel_cfe_auto.bin; cd /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images; zip vuplus-image-bm750-20120127221554_usb.zip vuplus/duo/*; rm -rf vuplus;
cd /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/
rm -f /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750.ubi
ln -s vuplus-image-bm750-20120127221554.rootfs.ubi /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750.ubi
Hi,
there is the error :
Check if you have the file for linux 64 in the right directory
try to run this :
/home/debian/Images/Vuplus3.1.1/bm750/build/tmp/staging/x86_64-linux/usr/bin/vfi3 /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.rootfs.ubi /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.boot.jffs2 /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.vmlinux.gz > /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/deploy/images/vuplus-image-bm750-20120127221554.nfi;
(in the same cmd, same line)
after chmod the same error:
/home/debian/Images/Vuplus3.1.1/bm750/build/tmp/work/bm750-oe-linux/vuplus-image-1.0-r0/temp/run.do_rootfs.9079: line 699: /home/debian/Images/Vuplus3.1.1/bm750/build/tmp/staging/x86_64-linux/usr/bin/vfi3: No such file or directory
