Errore in fase di arresto o riavvio
marcodream
Salve a tutti,
ho un problema con la ultima OBH sul mio VuDuo, mi spiego meglio ho rifleshato il tutto pensando di risolvre il problema ma lo stesso si rispresenta, spesso quando spengo o riavvio il dec va in errore in allegato il crashlog grazie a tutti per l'aiuto
<?xml version="1.0" encoding="utf-8"?>
<openpli>
<enigma2>
<crashdate>lun ago 17 10:30:26 2015</crashdate>
<compiledate>Jul 13 2015</compiledate>
<contactemail>vuplus-community.net</contactemail>
<skin>skin.xml</skin>
<sourcedate>2015-07-13</sourcedate>
<branch>(no branch)</branch>
<rev>217270c</rev>
<version>4</version>
</enigma2>
<image>
<stbmodel>duo</stbmodel>
<kernelversion>
<!-- Cannot allocate memory -->
</kernelversion>
<kernelcmdline>bmem=118M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync</kernelcmdline>
<imageversion>
<!-- No such file or directory -->
</imageversion>
<imageissue>
<![CDATA[
OpenBlackHole 0.1 %h
</imageissue>
</image>
<crashlogs>
<enigma2crashlog>
<![CDATA[
apError
< 2957.947645> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2957.947874> [eDVBSectionReader] DMX_SET_FILTER pid=0
< 2957.960521> [eDVBFrontend] set dynamic current limiting
< 2957.961732> [eDVBLocalTimerHandler] diff is 1
< 2957.961937> [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
< 2958.072380> [eDVBLocalTimerHandler] update RTC
< 2958.072574> [eDVBLocalTimerHandler] time update to 10:30:07
< 2958.072659> [eDVBLocalTimerHandler] m_time_difference is 1
< 2958.072731> [eDVBLocalTimerHandler] set Linux Time
< 2958.079908> [eDVBChannel] getDemux cap=00
< 2958.117080> [eDVBServicePMTHandler] PATready
< 2958.117575> [eDVBServicePMTHandler] use pmtpid 0103 for service_id 0004
< 2958.117741> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.117966> [eDVBSectionReader] DMX_SET_FILTER pid=259
< 2958.121982> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.122316> [eDVBSectionReader] DMX_SET_FILTER pid=0
< 2958.143998> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.144343> [eDVBSectionReader] DMX_SET_FILTER pid=256
< 2958.147256> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.147508> [eDVBSectionReader] DMX_SET_FILTER pid=17
< 2958.270942> [eDVBServicePlay] eventNewProgramInfo timeshift_enabled=0 timeshift_active=0
< 2958.274150> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.274383> [eDVBSectionReader] DMX_SET_FILTER pid=7879
< 2958.280198> [eDVBServicePlay] have 1 video stream(s) (0686), and 2 audio stream(s) (0687, 0688), and the pcr pid is 0686, and the text pid is 0653
< 2958.281602> [eTSMPEGDecoder] decoder state: play, vpid=0686, apid=0687
< 2958.289389> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.289746> [eDVBSectionReader] DMX_SET_FILTER pid=7879
< 2958.373767> [eDVBCIInterfaces] gotPMT
< 2958.373962> [eDVBCAService] don't build/send the same CA PMT twice
< 2958.374355> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.374540> [eDVBSectionReader] DMX_SET_FILTER pid=259
< 2958.381838> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.382225> [eDVBSectionReader] DMX_SET_FILTER pid=257
< 2958.426548> [eDVBServicePMTHandler] AITready
< 2958.426818> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.427093> [eDVBSectionReader] DMX_SET_FILTER pid=7839
< 2958.429911> [eDVBServicePMTHandler] AIT: Programmi TV SAT
[Dish] tuning failed
< 2958.546238> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.546529> [eDVBSectionReader] DMX_SET_FILTER pid=258
< 2958.570546> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.570832> [eDVBSectionReader] DMX_SET_FILTER pid=259
< 2958.646351> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.646676> [eDVBSectionReader] DMX_SET_FILTER pid=18
< 2958.678257> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.678539> [eDVBSectionReader] DMX_SET_FILTER pid=261
< 2958.687464> [eDVBServicePMTHandler] OCready
[AutoRes] determineContent
< 2958.793805> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.794170> [eDVBSectionReader] DMX_SET_FILTER pid=262
< 2958.826581> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2958.826864> [eDVBSectionReader] DMX_SET_FILTER pid=263
< 2958.914924> [eDVBServicePMTHandler] sdt update done!
action -> InfobarChannelSelection keyRight
< 2959.283927> [eDVBServicePlay] timeshift
playing 1:0:1:CEA:1518:13E:820000:0:0:0:
< 2959.287098> [eDVBCAService] free slot 0 demux 0 for service 1:0:1:4:1770:110:820000:0:0:0:
< 2959.287413> [eDVBCAService] free service 1:0:1:4:1770:110:820000:0:0:0:
< 2959.341143> [eTSMPEGDecoder] decoder state: play, vpid=ffffffff, apid=ffffffff
< 2959.341522> [eDVBPCR0] DEMUX_STOP ok
< 2959.342000> [eDVBPCR0] destroy
< 2959.342266> [eDVBVideo0] DEMUX_STOP ok
< 2959.346035> [eDVBVideo0] VIDEO_STOP ok
< 2959.349711> [eDVBVideo0] destroy
< 2959.350173> [eDVBAudio0] AUDIO_STOP ok
< 2959.354418> [eDVBAudio0] DEMUX_STOP ok
< 2959.354620> [eDVBAudio0] AUDIO_CONTINUE ok
< 2959.364846> [eDVBAudio0] destroy
< 2959.365186> [eDVBText0] DEMUX_STOP ok
< 2959.368902> [eDVBText0] destroy
< 2959.377684> [eDVBResourceManager] start release channel timer
getResolvedKey config.usage.remote_fallback failed !! (Typo??)
< 2959.421356> [eDVBServicePlay] timeshift
not pauseable.
< 2959.424179> [eDVBServicePlay] timeshift
not pauseable.
< 2959.428741> [eDVBServicePlay] timeshift
not pauseable.
< 2959.433151> [eDVBServicePlay] timeshift
new service started! trying to download cuts!
download failed, no cuesheet interface
RemovePopup, id = ZapError
< 2959.438164> [eDVBLocalTimerHandler] remove channel 0x2901540
< 2959.438367> [eEPGCache] remove channel 0x2901540
< 2959.447674> [eDVBResourceManager] allocate channel.. 1518:013e
< 2959.455819> [eDVBFrontend] (0)tune
< 2959.456086> [eDVBSatelliteEquipmentControl] RotorCmd ffffffff, lastRotorCmd ffffffff
< 2959.456256> [eDVBFrontend] prepare_sat System 0 Freq 11804000 Pol 1 SR 27500000 INV 2 FEC 2 orbpos 130 system 0 modulation 1 pilot 2, rolloff 0
< 2959.456372> [eDVBFrontend] tuning to 1204 mhz
< 2959.456464> [eDVBChannel] OURSTATE: tuning
< 2959.456555> [eDVBServicePMTHandler] allocate Channel: res 0
< 2959.456859> [eDVBCIInterfaces] addPMTHandler 1:0:1:CEA:1518:13E:820000:0:0:0:
< 2959.457030> [eDVBChannel] getDemux cap=00
< 2959.457109> [eDVBResourceManager] allocate demux cap=00
< 2959.457490> [eDVBResourceManager] allocating demux adapter=0, demux=0, source=0 fesource=0
< 2959.457640> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.465967> [eDVBFrontend] set static current limiting
< 2959.467917> [eDVBFrontend] set sequence pos 3
< 2959.468881> [eDVBFrontend] set sequence pos 3
< 2959.469762> [eDVBFrontend] update current switch params
< 2959.470467> [eDVBFrontend] startTuneTimeout 5000
< 2959.470944> [eDVBFrontend] setFrontend 1
< 2959.471259> [eDVBFrontend] setting frontend 0
< 2959.485843> [eDVBFrontend] (0)fe event: status 0, inversion off, m_tuning 1
< 2959.486128> [eDVBFrontend] sleep 500ms
< 2959.598819> [eDVBFrontend] (0)fe event: status 1f, inversion off, m_tuning 2
< 2959.599077> [eDVBChannel] OURSTATE: ok
< 2959.599159> [eDVBLocalTimerHandler] channel 0x2901540 running
< 2959.599289> [eDVBChannel] getDemux cap=00
< 2959.599436> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.599625> [eDVBSectionReader] DMX_SET_FILTER pid=20
< 2959.603120> [eEPGCache] channel 0x2901540 running
< 2959.603281> [eDVBChannel] getDemux cap=00
< 2959.603377> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.603566> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.603696> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.603827> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.603956> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.604130> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.604268> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.604398> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.604550> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.604681> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.604811> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.604939> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.605102> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.605305> [eEPGCache] next update in 2 sec
< 2959.605437> [eDVBResourceManager] stop release channel timer
< 2959.605518> [eDVBChannel] getDemux cap=00
< 2959.605589> [eDVBServicePMTHandler] ok ... now we start!!
< 2959.605706> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.605847> [eDVBSectionReader] DMX_SET_FILTER pid=0
< 2959.697770> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.698136> [eDVBSectionReader] DMX_SET_FILTER pid=18
< 2959.707822> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.708095> [eDVBSectionReader] DMX_SET_FILTER pid=0
< 2959.747142> [eDVBServicePMTHandler] PATready
< 2959.747316> [eDVBServicePMTHandler] use pmtpid 0104 for service_id 0cea
< 2959.747455> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.747652> [eDVBSectionReader] DMX_SET_FILTER pid=260
< 2959.750333> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.750605> [eDVBSectionReader] DMX_SET_FILTER pid=0
< 2959.766809> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.767150> [eDVBSectionReader] DMX_SET_FILTER pid=104
< 2959.769767> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.770124> [eDVBSectionReader] DMX_SET_FILTER pid=17
< 2959.792125> [eDVBServicePlay] eventNewProgramInfo timeshift_enabled=0 timeshift_active=0
< 2959.794842> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.795145> [eDVBSectionReader] DMX_SET_FILTER pid=6016
< 2959.800513> [eDVBServicePlay] have 1 video stream(s) (0201), and 2 audio stream(s) (028b, 02ef), and the pcr pid is 0201, and the text pid is ffffffff
< 2959.801111> [eDVBChannel] getDemux cap=01
< 2959.801197> [eDVBResourceManager] allocate demux cap=01
< 2959.801276> [eDVBResourceManager] allocating shared demux adapter=0, demux=0, source=0
< 2959.812924> [eTSMPEGDecoder] decoder state: play, vpid=0201, apid=028b
< 2959.813250> [eDVBPCR0] DMX_SET_PES_FILTER pid=0x0201 ok
< 2959.813354> [eDVBPCR0] DEMUX_START ok
< 2959.817943> [eDVBAudio0] DMX_SET_PES_FILTER pid=0x028b ok
< 2959.818185> [eDVBAudio0] DEMUX_START ok
< 2959.818586> [eDVBAudio0] AUDIO_SET_BYPASS bypass=1 ok
< 2959.826361> [eDVBAudio0] AUDIO_PAUSE ok
< 2959.829914> [eDVBAudio0] AUDIO_PLAY ok
< 2959.840493> [eDVBVideo] Video Device: /dev/dvb/adapter0/video0
< 2959.840718> [eDVBVideo] demux device: /dev/dvb/adapter0/demux0
< 2959.845163> [eDVBVideo0] VIDEO_SET_STREAMTYPE 0 - ok
< 2959.849408> [eDVBVideo0] DMX_SET_PES_FILTER pid=0x0201 ok
< 2959.849517> [eDVBVideo0] DEMUX_START ok
< 2959.849870> [eDVBVideo0] VIDEO_FREEZE ok
< 2959.853726> [eDVBVideo0] VIDEO_PLAY ok
< 2959.867317> [eDVBVideo0] VIDEO_SLOWMOTION 0 ok
< 2959.870817> [eDVBVideo0] VIDEO_FAST_FORWARD 0 ok
< 2959.875243> [eDVBVideo0] VIDEO_CONTINUE ok
< 2959.880318> [eDVBAudio0] AUDIO_CONTINUE ok
< 2959.888696> [eDVBTeletextParser] Starting!
< 2959.888797> [eDVBTeletextParser] disable teletext subtitles page ffffffffffffffff (und)
< 2959.888895> [eDVBPESReader] Created. Opening demux
< 2959.888985> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.889495> [eDVBTeletextParser] created teletext subtitle PES reader!
< 2959.889691> [eDVBPESReader] Created. Opening demux
< 2959.889806> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.890289> [eDVBTeletextParser] starting PES reader on pid=ffffffff
< 2959.892323> [eDVBServicePlay] timeshift
not pauseable.
< 2959.895206> [eDVBServicePlay] timeshift
not pauseable.
< 2959.900517> [eDVBServicePlay] timeshift
< 2959.910502> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2959.910792> [eDVBSectionReader] DMX_SET_FILTER pid=6016
[AutoRes] service changed
< 2960.007211> [eDVBCAService] new service 1:0:1:CEA:1518:13E:820000:0:0:0:
< 2960.007564> [eDVBCAService] add demux 0 to slot 0 service 1:0:1:CEA:1518:13E:820000:0:0:0:
< 2960.007750> [eDVBCIInterfaces] gotPMT
< 2960.011853> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2960.013950> [eDVBSectionReader] DMX_SET_FILTER pid=260
< 2960.026761> [eDVBFrontend] set dynamic current limiting
< 2960.029747> [eDVBLocalTimerHandler] diff is -1
< 2960.030102> [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
< 2960.140399> [eDVBLocalTimerHandler] update RTC
< 2960.140613> [eDVBLocalTimerHandler] time update to 10:30:08
< 2960.140693> [eDVBLocalTimerHandler] m_time_difference is -1
< 2960.140765> [eDVBLocalTimerHandler] set Linux Time
< 2960.145825> [eDVBChannel] getDemux cap=00
< 2960.178596> [eDVBServicePMTHandler] AITready
< 2960.178816> [eDVBServicePMTHandler] AIT: Rai News
< 2960.178903> [eDVBServicePMTHandler] AIT: Rai Replay
< 2960.178985> [eDVBServicePMTHandler] AIT: Rai Sport
< 2960.179148> [eDVBServicePMTHandler] AIT: TGR
< 2960.179228> [eDVBServicePMTHandler] AIT: Telecomando
< 2960.179364> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2960.179552> [eDVBSectionReader] DMX_SET_FILTER pid=3010
< 2960.187353> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2960.187614> [eDVBSectionReader] DMX_SET_FILTER pid=262
< 2960.244389> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2960.244678> [eDVBSectionReader] DMX_SET_FILTER pid=128
< 2960.594907> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2960.595253> [eDVBSectionReader] DMX_SET_FILTER pid=260
< 2960.748322> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2960.748606> [eDVBSectionReader] DMX_SET_FILTER pid=103
< 2960.917532> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2960.917889> [eDVBSectionReader] DMX_SET_FILTER pid=256
< 2960.921432> [eDVBVideo0] VIDEO_GET_EVENT SIZE_CHANGED 720x576 aspect 2
[AutoRes] got event evVideoSizeChanged
< 2961.268710> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
< 2961.269109> [eDVBSectionReader] DMX_SET_FILTER pid=126
< 2961.462372> [eDVBServicePMTHandler] sdt update done!
< 2961.611088> [eEPGCache] start caching events(1439800209)
< 2961.611329> [eDVBSectionReader] DMX_SET_FILTER pid=3842
< 2961.615068> [eDVBSectionReader] DMX_SET_FILTER pid=3003
< 2961.618901> [eDVBSectionReader] DMX_SET_FILTER pid=18
< 2961.627621> [eDVBSectionReader] DMX_SET_FILTER pid=18
< 2961.641196> [eDVBSectionReader] DMX_SET_FILTER pid=18
< 2961.659244> [eDVBSectionReader] DMX_SET_FILTER pid=5000
< 2961.662055> [eDVBSectionReader] DMX_SET_FILTER pid=5000
< 2961.669298> [eDVBSectionReader] DMX_SET_FILTER pid=57
action -> InfobarChannelSelection keyUp
action -> ChannelSelectBaseActions keyLeft
action -> OkCancelActions cancel
< 2966.101475> [eDVBServicePlay] timeshift
action -> InfobarShowHideActions hide
< 2968.705103> [eEPGCache] abort non avail nownext reading
< 2968.721072> [eEPGCache] abort non avail schedule reading
< 2968.731147> [eEPGCache] abort non avail schedule other reading
< 2968.734788> [eEPGCache] abort non avail netmed schedule reading
< 2968.746180> [eEPGCache] abort non avail netmed schedule other reading
< 2968.750419> [eEPGCache] abort non avail FreeSat schedule_other reading
< 2968.758700> [eEPGCache] abort non avail viasat reading
action -> GlobalActions power_down
action -> GlobalActions power_long
Show shutdown Menu
Standby TryQuitMainloop
Standby Standby
SleepTimerEdit SleepTimerEdit
action -> GlobalActions power_up
action -> OkCancelActions ok
okbuttonClick
< 2971.875619> [eDVBCAService] free slot 0 demux 0 for service 1:0:1:CEA:1518:13E:820000:0:0:0:
< 2971.875987> [eDVBCAService] free service 1:0:1:CEA:1518:13E:820000:0:0:0:
< 2971.925984> [eTSMPEGDecoder] decoder state: play, vpid=ffffffff, apid=ffffffff
< 2971.926270> [eDVBPCR0] DEMUX_STOP ok
< 2971.926650> [eDVBPCR0] destroy
< 2971.926783> [eDVBVideo0] DEMUX_STOP ok
< 2971.929279> [eDVBVideo0] VIDEO_STOP ok
< 2971.932962> [eDVBVideo0] destroy
< 2971.933390> [eDVBAudio0] AUDIO_STOP ok
< 2971.937895> [eDVBAudio0] DEMUX_STOP ok
< 2971.938169> [eDVBAudio0] AUDIO_CONTINUE ok
< 2971.947639> [eDVBAudio0] destroy
< 2971.955924> [eDVBResourceManager] start release channel timer
[SKIN] Parsing embedded skin <embedded-in-'TryQuitMainloop'>
connectionLost? [Failure instance: Traceback (failure with no frames): <class 'twisted.internet.error.ConnectionLost'>: Connection to the other side was lost in a non-clean fashion: Connection lost.
set wakeup time to 2015/08/17 11:10
EXCEPTION IN PYTHON STARTUP CODE:
File "/usr/lib/enigma2/python/mytest.py", line 571, in <module>
plugins.shutdown()
File "/usr/lib/enigma2/python/Components/PluginComponent.py", line 146, in shutdown
File "/usr/lib/enigma2/python/Components/PluginComponent.py", line 38, in removePlugin
File "/usr/lib/enigma2/python/Plugins/Extensions/DLNABrowser/plugin.py", line 908, in autostart
ps_str = os.popen('cat /etc/mtab | grep djmount').read()
OSError: [Errno 12] Cannot allocate memory
< 2972.315061> [MAIN] (exit code 5)
< 2975.458766> [gRC] main thread is non-idle! display spinner!
</enigma2crashlog>
</crashlogs>
</openpli>
Salve a tutti,
<openpli>
<enigma2>
<rev>217270c</rev>
</enigma2>
<image>
<kernelversion>
</kernelversion>
<imageversion>
</imageversion>
<imageissue>
<![CDATA[
</imageissue>
</image>
<crashlogs>
<enigma2crashlog>
<![CDATA[
apError
not pauseable.
not pauseable.
not pauseable.
not pauseable.
not pauseable.
Show shutdown Menu
Standby Standby
okbuttonClick
plugins.shutdown()
</enigma2crashlog>
</crashlogs>
</openpli>
Sembra che ti sia finita la RAM.... hai provato a creare un file di swap da almeno 128Mb?
dopo aver rifleshato no, ma la la precedente aveva 256mb di swap..e l'errore lo dava lo stesso....
comunque riprovo con questa e ti tengo aggiornato (è indifferente se lo swap lo creo sul HD) perche la penna pur essendo mappata regoralmente e ci salvo l'epg picon ...non me la vede per creare lo swap !!!!
adesso sembra che la penna la veda per poter creare lo swap,
una volta creato se riavvio lo swap non viene riconosciuto ma devo ricrearlo ogni volta .... !!! la cosa succede sia se lo creo sia sulla penna usb o sull HD ad ogni riavvio lo perde !!!
altro problema che mi succedde spesso e che se provo spegnere il dec sul display rimane la scritta spegnimento e il dec non si spegne ..... devo spegnerlo con interruttore posteriore....
mi sa che è arrivato il momento di cambiare dec !!!
