Hi,
since last firmware update my box gets only 100mbits lan connection while before worked correctly at 1gb.
Is there any way to force gigabit instead auto-negotiation?
thankyou
Verify the cable pin outs ---> by this schema:
1000BASE-T (also known as IEEE 802.3ab) is a standard for gigabit Ethernet over copper wiring. It requires, at least Category 5 cable (the same as 100BASE-TX), but Category 5e ("Category 5 enhanced") or Category 6 cable may also be used and are often recommended. 1000BASE-T requires all four pairs to be present and is far less tolerant of poorly installed wiring than 100BASE-TX.
Pin Name Description TIA/EIA 568A TIA/EIA 568B
1 BI_DA+ Bi-directional pair A+ (tranceive)
white/green
white/orange
2 BI_DA- Bi-directional pair A- (tranceive)
green
orange
3 BI_DB+ Bi-directional pair B+ (receive)
white/orange
white/green
4 BI_DC+ Bi-directional pair C+
blue
blue
5 BI_DC- Bi-directional pair C-
white/blue
white/blue
6 BI_DB- Bi-directional pair B- (receive)
orange
green
7 BI_DD+ Bi-directional pair D+
white/brown
white/brown
8 BI_DD- Bi-directional pair D-
brown
brown
Notes
- T568A and T568B are the two color codes used for wiring eight-position RJ45 modular plugs. Both are allowed under the ANSI/TIA/EIA wiring standards. The only difference between the two color codes is that the orange and green pairs are interchanged. T568A wiring pattern is recognized as the preferred wiring pattern for this standard because it provides backward compatibility to both one pair and two pair USOC wiring schemes. The T568B standard matches the older ATA&T 258A color code and is/was(?) the most widely used wiring scheme. It is also permitted by the ANSI/TIA/EIA standard, but it provides only a single pair backward compatibility to the USOC wiring scheme. The U.S. Government requires the use of the preferred T568A standard for wiring done under federal contracts.
- Each network segment cable length may be up to 100 meters, although several chip manufacturers claim 150 meters.
- Autonegotiation is a requirement for using 1000BASE-T, according to the standard.
- Several device drivers will allow you to force 1000 Mbps full duplex to eliminate autonegotiation issues.
