Event info in front display
CapricornDog
Hi all I have a problem with my solo4k the event info in the front display does not update with an event change, I have to switch channels to get it to update.
I'm running the latest BH 3.0.2.I image and have the "Front panel picons for Vu+ solo4k on black hole 3.x images by Evo v1.2" package installed.
Does anyone know why the info does not update?
Ok after some trial and error I have come to the conclusion that there is a incompatibility issue with BH3.0.2.x and autotimer plugin.
All work as it should until I install autotimer and setup some timers with it, then the problem starts.
I have now flashed open blackhole 0.6 and its all working great.
