Exchange Stream Port openbh 5.0.013
easy come
Hello,
I want to change the port from 8001 to 8044 but it doesn't work on openbh 5.0.013.
I changed from OpenWebif the port changes but it doesn't open anything on port 8044
With the port changed in 8044, the streaming still works on 8001
I can't modify web.py, stream.py, stream.pyo now have the .pyc extension.
My receiver VU+ uno 4k se
Can someone help me
Thank you.
What does it mean: "I want to change the port from 8001 to 8044 but it doesn't work on openbh 5.0.013"?
Did you change the port and OWIF or else don't work?
Or you did not manage to find how to change the port? If is this last, you need to change it by OpenWebIf plugin settings.
Yes, I changed the owif from 8001 to 8044 and save.
The application changes to 8044, but streaming works on port 8001
I have open port 8001 but I have many connections to the receiver
192.168.1.33:8001 ns3130570.ip-51-68-206.eu:58338 ESTABLISHED
192.168.1.33:8001 catv-176-63-25-70.catv.fixed.vodafone.hu:50635 ESTABLISHED
192.168.1.33:8001 unn-169-150-196-120.datapacket.com:50677 ESTABLISHED
I managed to put ban ip from the router openwrt.
Perhaps it is better to redirect a door in the router for door 8001... This is how I have, because if I want to use FalBacktuner internally, this is set for 8001. Externally there is a door to 8001, and the 8001 is closed.
For example, 51000 to 8001 (as long as the router allows it). You can also activate the streaming authentication in which to access user/passwd.
This three nominated files are at OpenWebif?
