Exiting RadioInfoBar quits radio mode
Charleswj39
Donating Member
I'm running BH 2.1.3 on a Solo2 and 2.1.4 on a Duo2. When I switch to radio, I can select the station that I want from the list. As expected it starts up with the RadioInfoBar displayed. Unexpectedly the bar does not disappear after a time. Clicking Exit on either remote takes me back to the TV station that I was watching. In both cases an image (?headphones) shows very briefly before the TV channel comes on. Is there a way to stop this happening and stay with the ?headphones image?
Has no-one else seen this? I'm surprised for it happens with both my tuners and I expect some to use their tuners to listen to radio. Perhaps a BH bug?
This is not BUG.
How do you mean this happens to both tuners.
This is normal when you press the radio button you switch in to Radio Mode.
If you want standard OSD then you go to the System Menu >> Customise
(Customise panel should be in Setup Mode Expert , if not change this first and Save)
Then in Customise Menu panel put Alternativ radio mode yes and SAVE
Then you can Hide OSD in Radio Mode with the OK button (or automatic, Hide Time you can change also in Customise panel) the same as for TV
Apologies - I have not been clear. Let me try again. This behaviour occurs on both tuners, Duo2 and Solo2.
I switch to Radio Mode and to my radio Favorites. I select a station. It starts playing. The Favorites list is still on the screen so I click the Exit button on the remote. I expect this to change the screen to an image. That image (? headphones) appears for a second or two. Then the tuner switches back to the last TV channel that I was watching. If I do not use the Exit button, the radio continues OK with the Favorites list on the screen.
As I do see the ?headphones image quickly, I thought that I might have found a little bug. It seems that I'm wrong. So if someone could explain how I can keep the radio playing but get the ?headphones image, I'd be grateful.
Well, that I have already written:
OK - got it. Thank you for your patience.
Somehow I hadn't expected the behaviour I wanted to be 'Alternative' as it was the standard on all the other tuners that I've used.
when you switch to radio on 19,2e 10847 V 22000 5/6 - there are 15 stations can you hear some noise? Im nothing...whats wrong? BH 2.1.0.1
