exteplayer3
Azam
Can others confirm issues with exteplayer3 on OBH 4.2 (latest update installed 30/9/18)?
I have uninstalled ServiceApp, rebooted box and reinstalled ServiceApp latest from feeds.
For me, it was working fine on OBH 4.2 but something appears to have been broken exteplayer3 after last online update.
Thanks
Azam
(Box is Vu+Uno 4K)
Yes they broke something in oe-a with the last changes they did.
Only causes a problem with online update for some reason, but they can't find the issue.
Only option is to reflash your box i'm afraid, however you will need to wait for the images to rebuild and be uploaded first.
A workaround for now, is to remove serviceapp before you online update.
Then reinstall serviceapp afterwards.
Doesn't help if you already online updated with serviceapp installed though.
