external HDD Issue!
a911
The BH Lover
Why?
When external HDD,,,,Connected thru e-sata, need to mount/mapped again & again, when its off , because BH does not recognize it!
Rgdz
a911
Yes it happen my friend (@Ludi Pera).
Probably it happens because VU+DUO is not in good cooperation with that HDD.
Are You initialized HDD in VU+ or on PC ? Which mark is HDD and how much rpm ?
Seagate and Its initialized within Vu+ !
Try to connect HDD to VU+ with USB if have that output,otherwise forma HDD on PC with "Acronis disk director" and test after.
Issue was solved, by adding attached file in the path:
/user/script
Then given attribut 755
Thanx 2, m00hamed for solution, and loinelmessi 4 testing!
