EyeTV Diversity in Ultimo?
Wild Bill
I see that the WinTV Nova-TD stick is only compatible with Windows. Given that I have Macs, in which I might want to use the stick from time to time, I found a similar dual tuner stick that is also compatible with OS X, the EyeTV Diversity. Is this stick compatible with the latest BH image? I believe that it should be with only the Diversity functionality not currently supported by Linux. Do any of you have any preferences regarding these or other dual tuner sticks? I have also seen that some people appear to have problems when using a tuner stick or USB flash drive in one of the rear USB slots and the Vu+ WIFI N USB dongle in the other. Has this now been resolved in the latest BH image?
I haven't tested USB DVB tuners into Ultimo because I've the internal DVB-T/C tuner.... I've connected some USB devices to my Ultimo (PCSC readers, pendrives and a Vu+ wifi dongle) and all works correctly. I've used an external powered USB hub to pilot 3 devices and the wifi stick is connected directly on the box. Hub and Wifi dongle are connected to the back of my box.
