EyeTV T2 Hybrid stick not detected and Cimergy DVB-T recognised but unknown fromtend
gogglebox
Hi,
I’ve just bought an eyeTV T2 hybrid stick, which isn’t being detected at all by BlackHole 3.0.5. I also have a Cinergy stick which is being detected but the Tuner Congifuration screen is showing unknown front end.
I’m not sure what driver I need for both sticks. I will try to do the debug soon. Any help from this information would be appreciated!
Here is the output from dmesg:
root@vusolo2:~# dmesg
scsi 1:0:0:0: Direct-Access ATA WDC WD10JPVX-60J 01.0 PQ: 0 ANSI: 5
usb 1-1: new high-speed USB device number 2 using ehci-brcm
sd 1:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
sd 1:0:0:0: [sda] 4096-byte physical blocks
sd 1:0:0:0: [sda] Write Protect is off
sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sd 1:0:0:0: Attached scsi generic sg0 type 0
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 1 port detected
ohci-brcm ohci-brcm.3: Broadcom STB OHCI
ohci-brcm ohci-brcm.3: new USB bus registered, assigned bus number 8
ohci-brcm ohci-brcm.3: irq 77, io mem 0x10490600
hub 8-0:1.0: USB hub found
hub 8-0:1.0: 1 port detected
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Success! Registering the characther device success with 0
blackhole initialised
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
Key type dns_resolver registered
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
sda: sda1
EBI CS0: setting up NAND flash (primary)
sd 1:0:0:0: [sda] Attached SCSI disk
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
NAND device: 256MiB, SLC, page size: 2048, OOB size: 64
brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Hamming ECC
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
nand_read_bbt: bad block at 0x000001ba0000
nand_read_bbt: bad block at 0x000002ce0000
nand_read_bbt: bad block at 0x000009560000
nand_read_bbt: bad block at 0x00000a660000
nand_read_bbt: bad block at 0x00000c900000
nand_read_bbt: bad block at 0x00000fb80000
Creating 4 MTD partitions on "brcmnand.0":
0x000001f00000-0x000010000000 : "rootfs"
0x000001f00000-0x000010000000 : "rootfs(redundant)"
0x000000200000-0x000000900000 : "kernel"
0x000000900000-0x000000a00000 : "mac"
UBI: attaching mtd0 to ubi0
usb 2-1: new high-speed USB device number 2 using ehci-brcm
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
random: nonblocking pool is initialized
usb 2-1.1: new high-speed USB device number 3 using ehci-brcm
usb-storage 2-1.1:1.0: USB Mass Storage device detected
scsi2 : usb-storage 2-1.1:1.0
usb 2-1.3: new high-speed USB device number 4 using ehci-brcm
usb 2-1.4: new high-speed USB device number 5 using ehci-brcm
hub 2-1.4:1.0: USB hub found
hub 2-1.4:1.0: 4 ports detected
UBI: scanning is finished
UBI: attached mtd0 (name "rootfs", size 225 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 1791, bad PEBs: 9, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 177/79, WL threshold: 4096, image sequence number: 392118284
UBI: available PEBs: 0, total reserved PEBs: 1791, PEBs reserved for bad PEB handling: 31
UBI: background thread "ubi_bgt0d" started, PID 55
ALSA device list:
No soundcards found.
UBIFS: parse sync
UBIFS: background thread "ubifs_bgt0_0" started, PID 58
UBIFS: recovery needed
usb 2-1.4.4: new high-speed USB device number 6 using ehci-brcm
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 221573120 bytes (211 MiB, 1745 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID 62ADFBB4-1008-414A-B405-C0A1A6D6E058, small LPT model
VFS: Mounted root (ubifs filesystem) on device 0:12.
devtmpfs: mounted
Freeing unused kernel memory: 192K (80760000 - 80790000)
scsi 2:0:0:0: Direct-Access SanDisk Cruzer Blade 1.26 PQ: 0 ANSI: 6
sd 2:0:0:0: Attached scsi generic sg1 type 0
sd 2:0:0:0: [sdb] 15633408 512-byte logical blocks: (8.00 GB/7.45 GiB)
sd 2:0:0:0: [sdb] Write Protect is off
sd 2:0:0:0: [sdb] Mode Sense: 43 00 00 00
sd 2:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
sdb: sdb1
sd 2:0:0:0: [sdb] Attached SCSI disk
UBI error: ubi_open_volume: cannot open device 0, volume 0, error -16
FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
udevd[87]: starting version 182
usb 2-1.3: Direct firmware load failed with error -2
usb 2-1.3: Falling back to user helper
smscore_load_firmware_from_file: line: 1168: failed to open firmware file "isdbt_rio.inp"
WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
b2d1467ad0461049c0de8f82f514447b0b8f016b tryfix v4l2_ctrl_check duplicate symbol #2
64955823cf3bd80743f1f3a5f7d50bd599d8affc tryfix v4l2_ctrl_check duplicate symbol - modify header
e8812dab0d410e2694451a73b421df6fd82b3b07 Merge branch 'bh-master_20140924_bh_dvb_usb_v2' of git.blackhole-community.net:repos/bh/vuplus_kernel into bh-master_20140924_bh_dvb_usb_v2
DVB: registering new adapter (Siano Rio Digital Receiver)
usb 2-1.3: DVB: registering adapter 1 frontend 0 (Siano Mobile Digital MDTV Receiver)...
usbcore: registered new interface driver smsusb
rtusb init rt2870 --->
=== pAd = e041d000, size = 511144 ===
usbcore: registered new interface driver rt2870
Adding 2097148k swap on /mnt/usb/swapfile. Priority:-1 extents:4 across:2099964k
procmk_init
bcm_event: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (_vuplus_solo2_)
bcm7356: hotplug_callback():
Hotplug - status.connected 1:0:0
Hotplug - connecting HDMI to display 0xe
[GP]:brcm_pwm_init
Hotplug - status.connected 1:1:2
brcm_demux_init: $Id: bcm_demux.c,v 0.7 $
[MPVR]: >> misc_pvr_init
[VID]: 6bcm7335_video_init
[AUD]: 6bcm7335_audio_init
BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (BCM7346 FE)...
BKNI_P_GetTrackAllocEntry_resize: resizing from 5376->8704
BKNI_Malloc(linuxkernel) top users:
blocks, bytes, filename:line
1024, 176128, portinginterface/hsm/src/common/bhsm.c:500
596, 131632, BSEAV/lib/utils/balloc.c:31
387, 24768, magnum/commonutils/mrc/src/bmrc_monitor.c:666
input: dreambox advanced remote control (native) as /devices/virtual/input/input0
[LCD]: registered
0:0
[CI]: registered ci0
[CI]: CI interface initialised
[DFP]: registered dbox fp
[DFP]: Scart 9597 is found 4
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc3
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1 0
[VID]: VIDEO_PLAY 1 2 0
[VID]: VIDEO_CONTINUE 1 1
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
[VID]: VIDEO_STOP 0 1
[VID]: VIDEO_SELECT_SOURCE 0 0
(Efuse for 3062/3562/3572) Size=0x2d [2d0-2fc]
RTMP_TimerListAdd: add timer obj e0464a78!
RTMP_TimerListAdd: add timer obj e0464aa8!
RTMP_TimerListAdd: add timer obj e0464ad8!
RTMP_TimerListAdd: add timer obj e0464a48!
RTMP_TimerListAdd: add timer obj e04649b8!
RTMP_TimerListAdd: add timer obj e04649e8!
RTMP_TimerListAdd: add timer obj e042f5ec!
RTMP_TimerListAdd: add timer obj e041ede4!
RTMP_TimerListAdd: add timer obj e041ee1c!
RTMP_TimerListAdd: add timer obj e042f690!
RTMP_TimerListAdd: add timer obj e042f58c!
RTMP_TimerListAdd: add timer obj e042f65c!
-->RTUSBVenderReset
Key1Str is Invalid key length(0) or Type(0)
Key2Str is Invalid key length(0) or Type(0)
Key3Str is Invalid key length(0) or Type(0)
Key4Str is Invalid key length(0) or Type(0)
1. Phy Mode = 5
2. Phy Mode = 5
NVM is Efuse and its size =2d[2d0-2fc]
phy mode> Error! The chip does not support 5G band 15!
RTMPSetPhyMode: channel is out of range, use first channel=1
3. Phy Mode = 9
AntCfgInit: primary/secondary ant 0/1
MCS Set = ff ff 00 00 01
0x1300 = 00064300
===>rt_ioctl_giwscan. 4(4) BSS returned, data->length = 863
==>rt_ioctl_siwfreq::SIOCSIWFREQ(Channel=11)
Rcv Wcid(1) AddBAReq
Start Seq = 00000000
RTMP_TimerListAdd: add timer obj e049531c!
RTMP_TimerListAdd: add timer obj e0493308!
NET: Registered protocol family 10
RTMP_TimerListAdd: add timer obj e0493348!
BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Siano Mobile Digital MDTV Receiver)...
[LCD]: unknown cmd 0x1015
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -868246032
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
FE tune
[AUD]: AUDIO_SELECT_SOURCE 0
[AUD]: AUDIO_SET_BYPASS_MODE 0
[AUD]: AC3 downmix 0 state : 0
[AUD]: AUDIO_PAUSE 0
[AUD]: AUDIO_PLAY 0 decoder start : 0
[VID]: VIDEO_SET_STREAMTYPE 1
[VID]: VIDEO_FREEZE 0 0
[VID]: VIDEO_PLAY 0 5 2
[VID]: VIDEO_SLOWMOTION 0 1
[VID]: VIDEO_FAST_FORWARD 0 1
[VID]: VIDEO_CONTINUE 0 1
[AUD]: AUDIO_CONTINUE 0 1 aph=0xcba7e280
[AUD]: Mute : 0
[AUD]: AUDIO_CHANNEL_SELECT 0
root@vusolo2:~#
