Fan control pwm value settings
shilev
What is your value there?
Default value was 10, but my hdd temp was very high, 47 C.
I tried with 80 and it has fallen to 42 C in 15 min.
But maybe pwm 80 is too high,i don't know..
I thought solo2 has automatic fan control against overheating..
So, what's your value of pwm in this hot days?
And what should be optimal hdd temp in standy?
Sent from my Nexus 7 using Tapatalk HD
I think mine is set to 90 or 110, can't check at the moment as not plugged in.
My temperature is about 40-42 with room temp of 22-34 so the fan is keeping temp constant in different room temperatures.
It concerned me a bit also thats why I remember, but have not played with settings recently.
Sent from my HTC Sensation Z710e using Tapatalk 2
isn't 90-110 pwm to high?
i thought my 80 (now i put it on 50) is too high.
i don't know how long can fan work in that speed :)
I don't know to be honest, was just fastest I could have it without noticeable noise.
Figured would be cheaper to change fan than other components.
47 C temperature was not problematic for modern HDD
temperature more than 50-55 C can shorten the life of HDD
But it is not quite well-tested and depends on other factors.
In general all under 50C is good.
