fan noise
azeemmir
hi
guys got my vu+duo,
working good
but i have 1 question ( my box is without hdd )
fan noice is irritating,
oki i can understand when box is on then it should work but even in stand by fan work and make noice, its not too much noice but its in my bedroom
so in night it make some irritating noice,
so my question is that it should stop in standby or it always works,
some time it stop in standby but in mid of night in standby mod fan start,
any idea guys what to do ,
plz thanx
hi
Thanx for reply i have see option,but can i do with this option, its showing timings pzl if can u explain , thanx in advance,
You can use timing if you like
but you can also switch OFF timing
If you have Fan basic action off .You Fan will not work in Standby
You have to SAVE your new settings.
But what do the fan duration on/off numbers represent? Is it recommended to keep the fan on or off in standby?
It is a timer setup: you can set the time which the fan is on and the time is off, the measure unit is seconds
I still don't get it...
- How can you enable the fan to work between 04.00-05.00 for example?
Ok, thanks. It seems though 100 seconds = maximum for Fan off, it won't go any higher.
It is not true
This plugin regulates the fan in standby mode
and only in Standby
here we have two possibilities
fan always off or on in standby
fan turned on a certain period
Each number is minutes rather than seconds
example you like fan 5 min on and fan 55 min off
you have to put and SAVE
Fan on duration time oo5
Fan off duration time 055
Example fan off
Use Fan timer no
Rgd MX
:ice: actually today i removed the cover on my vu+ duo and used high compressed air to blow the dust away from both fan and motherboard, as theres a lot of dust entering box.
but be carefull hold a finger or a screwdriver on one fan blade so it doesnt spin up in high rpm,,as this can cause fan to stop working.
and please dont do this if youre not exactly shure what youre doing.....
Thanks, I thought they were seconds. It is clear now. Do you think there could be a problem leaving the fan always off on standby?
If your box is not in a closed space
It would not be a problem ,at least I think so.
Im not using fan in standby.
It is important that the box is not closed and heated by other electronic tv/video etc
Rgd MX
hi
guys got my vu+duo,
working good
plz thanx
Hi
I like to tell you how to get rid of the noise:
Open the box and remove the power to the fan, then you have yotal silence.
I n my hove I have 2 vu+ boxes, now running on second year without any problem,
and both my boxes are always on 24/7 (never on standby) because I use Logitech
remotes, and they often fail to switch the VU+ on an of .
and both s without fans, that the
