Solo2 Faulty tuner or ...?
andriuxa
Hey guys, I am experiencing some problems with my Solo 2. I am on Astra 28.2 ftw channels, signal strength is around 82 %. Some channels are ok, but on some of them I get "tune failed" message, then the signal drops to 0. Which is very strange, because the same channels are working properly sometimes. And it is not always the same channels I get "tune failed" all the time. Could it be problem with my Tuner (it might be very sensitive or smth, because on the other Box I have used before all of the channels was ok). Does somebody have a clue what could be wrong? Maybe I should get sat-amplifier thing or just try to set my dish closer to 100%? Thanks in advance.
Oh and btw, when I bought it a month or so ago, all channels were working. Mystery :)
Hello
I take it you have carried out the basic checks of the tuner connection at the back of box or could it be your channel list needs updated, whats the latest channel list you have because the latest update was on 13th oct
Also what box do you have?
Some changes on 28,2E position are in progress. Depends on your location, but you can lose some channels in next weeks.
Hello
Well... the same channel is showed as "tune failed", but after few minutes it is on again... (I am starting to doubt my brain :D ) I have updated all the lists even did a full scan, still no luck. Have also tried to connect the same dish to my old dm800 and all the channels seems to work just fine.
P.S. I have written in my first post that I am using Solo2
buongiorno
anche io noto lo stesso problema penso sia dovuto ai tuner perché con il mio 500hd andava tutto bene mentre con il solo 2 non funziona bene speriamo prendano provvedimenti .
