FCC-Fast channel change for OBH
AlexWilMac
Moderator
Is it this plugin installable also in OBH? I believed it was available among Addons os Plugins but I was wrong.
Well now there is FCC in some of the OE-A images here:
http://code.vuplus.com/index.html?action=image&image=30&model=vuuno4k
I personally tested it on my Uno 4K.
So if you could kindly add FCC support on OBH and publish the plugin on OBH feeds... (the plugin itself is just for configuration, of course deeper support must be added)
Lack of FCC is the only thing keeping me on BH at the moment, I would rather be on OBH..
Wich image that is OE-A based has FCC ( Fast Channel Change ) ?
The link from your post is from Vuplus Original image that is not OE-A based and is OE-3.0 version from Vuplus. BlackHole 3.0.4D has FCC on image because it is based on Vuplus original code.
The porting of FCC to OE-A based images involves lots of enigma2 code changes, so it´s not so simple.
Ok, my mistake, I thought OE-3.0 was OE-A based.
Another question, if Blackhole is based on those Vuplus original firmwares from that link, why those images have dvb-t kernel modules for ARM dvb-t usb drivers such as AF9035 and dib0070 and BH doesn’t?
I should mention I’m on bh 3.0.4A, maybe that changed in D as I see “updated drivers” in the changelog, gonna try it asap!
regards
