FEC problem
mrbeach
What can I do with my VU + solo 4K can not search channels right?
For example, if a channel should have FEC 3/4 then the channel is not found!
You must enter settings to change to Auto FEC.
This is very irritating and time consuming.
It seems you are always reporting an hardware issue! :unsure:
From all of your posts, regarding Duo2, and now Solo4k, you have never commented as:
  1. My STB model is ???
  2. The firmware ( image ) is BH or OBH ... versiion?
  3. I have this issue when i pushed up the button ????
Allways an hardware issue ... sorry, but this is strange enough! ;)
Would you mind, please to post on the right section as follows?
thansk in advance
Note: Help us, in order, we can give the desired help to you.
Ok sorry .
the box is VU+ solo 4K
The image is open vix latest
And i Also has a vu + solo2 with the same image and that works OK
An example of what I mean is NASA TV UHD on 13E 11373 H that will have FEC be 2/3 but with that setting I get no signal at all and no channels are found, if I set FEC to auto then all channels go in
This forum is for Black Hole, and Open Black Hole, for other images you should post on the relevant forum, where others use the same image, and can help.
One question, after you've scanned in the channels do they show the correct FEC, in the channel information?
Thought this was a forum for VU + because it's called vuplus-community.net
And in channel information it says auto .
One question if it is allowed which is the easiest way to edit satellite XML
This is home forum image Bh and OBH.
But we are big family people who have VU+ boxes and is no problem ask about other images too.
Im alvays will be try help becouse we are big family.
You try download from feed vaniball setting and after reboot box upload your seeting too box ?
This will help sometimes.
