Feeds out
I tried even now and it works (apart, of course, for the libraries not possible to update because of the dependencies issue).
There must be something in your connection. Or, you can try OpenDNS (or Google ones, whom I don't like because I don't like Google, actually).
Connection status and ability to download are two different things, sometimes. That's why I talked about DNS.
Sometimes this is the only chance to download from BH/OBH feeds.
In case you did not find:
OPENDNS are
208.67.222.222
208.67.220.220
GOOGLE DNS
8.8.8.8
8.8.4.4
Thanks Alexwillmac for your suggestions
I know Opendns and i used them....
Nothing changes.....
This night at 2.30am until 3.30am I also tried reflashing but nothing has changed .... it doesn't depend on me and my line
Bye
Hall
Then ... if it depended on my line ... why do OenATV and OpenSpa that I use in multiboot have no problem?
Hall
Again....
openbh 4.3 vuduo2
vuduo2 login: root
Password:
root@vuduo2:~# opkg update
Collected errors:
* opkg_lock: Could not lock /run/opkg.lock: Resource temporarily unavailable.
