Hi,
I used to be able to connect to the Vu+with Filezilla. Then last week, after messing around trying to get vlc plugin to work(unsuccessfully), I was no longer able to connect with Filezilla. I am getting connection refused.
I have deleted the VLC server I had set up. No change.
I have tried it with firewall disabled. No luck.
I dont have a router , just the computer connected directly to the box.
I was using root/password to try log in, also root/root.
I was wondering if I had changed the login name and password on the box with my VLC trials. Is there a way I can check this out or reset the username / passowrd?
Hi,
btw...To login you must use your current root account.
do you mean with "root"/"password", in Filezilla? If so that no longer works which is why I was wondering if I had inadvertantly changed the login in in fo in the VU+
$ telnet 10.42.43.1
Trying 10.42.43.1...
telnet: Unable to connect to remote host: Connection refused
$ telnet 10.42.43.1
