FileZilla
a911
The BH Lover
FileZilla 3.5.0 - Final
FileZillaFileZilla Client is a fast and reliable cross-platform FTP, FTPS and SFTP client with lots of useful features and an intuitive interface. It is a powerful FTP-client for 32-bit MS Windows XP, Vista and Windows 7 for file uploading and downloading to and from your FTP site, server, or host.
The program lets you transfer files and navigate among folders, Web sites, and your computer. This software enables you to perform multiple file transfers simultaneously. FileZilla is open source software distributed under the terms of the GNU General Public License. It has been designed for ease of use and with support for as many features as possible, while still being fast and reliable.
Features of FileZilla include the following:
• Easy to use
• Supports FTP, FTP over SSL/TLS (FTPS) and SSH File Transfer Protocol (SFTP)
• Cross-platform. Runs on Windows, Linux, *BSD, OSX and more
• Available in many languages
• Supports resume and transfer of large files >4GB
• Powerful Site Manager and transfer queue
• Drag & drop support
• Configurable Speed limits
• Filename filters
• Network configuration wizard
• Ability to resume Uploads/Downloads (if the server supports it)
• Custom Commands
• Site Manager with folders
• Keep Alive system
• Timeout detection
• SOCKS4/5 and HTTP1.1 Proxy support
• GSS authentication and encryption using Kerberos
Changes in FileZilla Client 3.5.0 (2011-05-22):
Bugfixes and minor changes:
* Don't create queue.xml anymore if it does not exist
* MSW: Progress lines in transfer queue now appear in correct position after changing the Windows theme
* MSW: Work around a bug in Windows where a list controls' scroll position changes without the control being notified in any way
* Several fixes to build system and environment
Thanx to Gruß Haisurfer for this useful tool!
FileZilla v. 3.5.3
# New features:​
* Ctrl+Shift+O can be used to toggle between modification time and filesize based directory comparison​
# Bugfixes and minor changes:​
* It is now possible to use custom passwords if using "anonymous" as user name​
* After un-hiding toolbar, update toolbar button states​
* Fix TLS compatibility issues with TLS 1.2 servers​
* MSW: Unset hidden attribute on FileZilla's settings files​
* Building FileZilla from source now requires wxWidgets 2.8.12 or higher.​
FileZilla_3.5.3_win32!
FileZilla Client
These FileZilla builds are vanilla builds from the SVN trunk.
They are compiled on Windows under MinGW with GCC.
Building environment:
* gnutls 2.12.19
* libgcrypt 1.4.6
* libgpg error 1.10
* libidn 1.25
* sqlite 3.7.13
* wxWidgets 2.8.12
* GCC 4.7.0
* NSIS Unicode 2.46.5
FileZilla Client 3.6.0
Changes:
3.6.0 (2012-11-10)
Fix a crash introduced since 3.5.3
IPv6-only hosts should no longer cause a crash in the network configuration wizard
3.6.0-rc1 (2012-11-02)
Do not show "Remember passwords?" dialog if connecting anonymously
Make wording in "Remember passwords?" dialog consistent.
Increase default TLS session lifetime
When asking for confirmation to delete files, state whether it's local or on the server
Fix right-to-left rendering of progress line in the transfer queue
3.6.0-beta1 (2012-10-21)
New features:
Auto-scroll file lists if dragging an item near the top or bottom
Add option to create empty files to the remote file list context menu
Support legacy servers sending directory listings in EBCDIC
Added Tango icon set
First-time users now get prompted whether they want to save passwords when first using the quickconnect bar
Greatly improve TLS performance by updating to GnuTLS 3.1.x with Nettle backend
FTP proxies now work with IPv6 addresses as proxy address
Handle expired TLS sessions when trying to reuse a session
TLS session reusing no longer fails with newer GnuTLS versions due to changed semantics of gnutls_session_get_data
Directory listings no longer sporadically fail if two connections try to list the same directory in parallel
Partially work around a Ubuntu-specific problem with modal dialogs not being modal resulting in crashes
FileZilla Client FileZilla 3.6.0.2
These FileZilla builds are vanilla builds from the SVN trunk.They are compiled on Windows under MinGW with GCC. Building environment:
* gnutls 2.12.20
* libgcrypt 1.4.6
* libgpg error 1.10
* libidn 1.26
* sqlite 3.7.15.1
* wxWidgets 2.8.12
* GCC 4.7.2
FileZilla client 3.7.0
New features:
-Show total transfer speed as tooltip over the transfer indicators
-List supported protocols in tooltip of host field in quickconnect bar
-Use TLS instead of the deprecated term SSL
-Reworded text when saving of passwords is disabled, do not refer to kiosk mode
-Improved usability of Update page in settings dialog
-Improve SFTP performance
-When navigating to the parent directory, highlight the former child
-When editing files, use high priority for the transfers
-Add label to size conditions in filter conditions dialog indicating that the unit is bytes
-Ignore drag&drop operations where source and target are identical and clarify the wording in some drop error cases
-Trim whitespace from the entered port numbers
-Slightly darker color of inactive tabs
-Ignore .. item in the file list context menus if multiple items are selected
-Display TLS version and key exchange algorithm in certificate and encryption details dialog for FTP over TLS connections.
-Fix typo
-Fix handling of remote paths containing double-quotes
-Fix crash when opening local directories in Explorer if the name contained characters not representable in the locale's narrow-width character set.
-Fix a memory leak in the host key verification dialog for SFTP
-Fix drag-scrolling in file lists with very low height
-Don't attempt writing XML files upon loading them
-Improve handling of legacy DDE file associations
-Fix handling of HTTPS in the auto updater in case a mirror redirects to HTTPS
FileZilla 3.7.2 Final | 1 Mb
FileZilla Client is a fast and reliable cross-platform FTP, FTPS and SFTP client with lots of useful features and an intuitive interface. The program lets you transfer files and navigate among folders, Web sites, and your computer. It is a powerful FTP-client for 32-bit and 64-bit Windows XP, Vista and Windows 7 for file uploading and downloading to and from your FTP site, server, or host. This software enables you to perform multiple file transfers simultaneously. FileZilla uses GSS authentication and encryption using Kerberos. It has been designed for ease of use and with support for as many features as possible, while still being fast and reliable. FileZilla is open source software distributed under the terms of the GNU General Public License. Runs on Windows, Linux, BSD, OSX and more. FileZilla is available in many languages.
* Easy to use
* Supports FTP, FTP over SSL/TLS (FTPS) and SSH File Transfer Protocol (SFTP)
* IPv6 support
* Available in many languages
* Supports resume and transfer of large files 4GB
* Tabbed user interface
* Powerful Site Manager and transfer queue
* Bookmarks
* Drag & drop support
* Configurable transfer speed limits
* Filename filters
* Directory comparison
* Network configuration wizard
* Remote file editing
* Keep-alive
* HTTP/1.1, SOCKS5 and FTP-Proxy support
* Logging to file
* Synchronized directory browsing
* Remote file search
3.7.2 (2013-08-06)
Fixed vulnerabilities:
Apply a fix for a security vulnerability in PuTTY as used in FileZilla to handle SFTP. See CVE-2013-4852 for reference.
Provided Linux binaries are now built against Debian Wheezy
FileZilla 3.9.0.4
Changes in 3.9.0.4:
Quote:
MSW: Fixed crash if starting file rename in an unusual way
OS X: Fixed a bug im wxWidgets so that a right-click after a left-click no longer counts as double-click
OS X: Fixed pasting of passwords into the "Enter password" dialog
OS X: Fixed context menu site manager tree not working
*nix, OS X: Fixed context menu of search dialog not working
Fixed loading of resources if FileZilla is installed in a directory containing the # character
Fixed support for SOCKS4 proxies
Attempt reading settings from temporary backup files if loading of settings files fails
