finaly kodi 15.2 on vu+
mohcinbamou
Hi friends, kodi 15.2 is now available for our boxes, here it is a beta version of openpli 4.0 for testing pearpes, tested by my own on vu+ solo se and it's working like a charme.
https://dl.dropboxusercontent.com/u/38760017/openpli-enigma2-5-vusolose_kodi_usb.zip
https://dl.dropboxusercontent.com/u/38760017/openpli-enigma2-5-vusolo2_kodi_usb.zip
https://dl.dropboxusercontent.com/u/38760017/openpli-enigma2-5-vuduo2_kodi_usb.zip
the original thread is :
http://forums.openpli.org/topic/40225-kodi-152-for-vusolose-vusolo2-and-vuduo2/
Bonjour tout le monde, enfin la malédiction de feu xbmc 13.2 est levée, je vous fais part d'une version expérimentale d'openpli 4.0 où kodi 15.2 fonctionne comme une horloge. Les liens sont en haut pour ceux qui veulent tester le travail de Senior Member.
Cordialement.
I installed this image on my VU+ Solo 2. Kodi 15.2 is not working in 1080p, only 720p.
Do you have the same problem ? I cannot modify the Kodi setup to 1080p.
Have a great day...Merci pour vos participations.
Reading previous posts I gather Kodi 15.2 is not compatible with uno. Is this so even with extra memory added?
Thank you for quick reply. I have since been searching online for wifi kodi xbmc receivers and on reading reviews I am interested. Whether it is worthwhile upgrading vu plus or getting one of the kodi receivers as they are relatively cheap. Any advice gratefully accepted.
