First vu box! zero
labbz0re
Hello!
im about to buy my first box.
in intrested in vu zero for the size.
Im only going to use it for IPTV. Can it handle that good? 1080i channels ac3, dts, 5.1 sound?
Is it possible to mount my network nas as harddrive to record live tv on?
And what is blackhole is it like Openatv? Had openatv on a old dm500hd before.
Sry for my bad english
/ Marcus
- OBh is good to iptv.
- 1080i channels ac3, dts, 5.1 sound? chanells work ok
- Is possible used NAS
- im personaly used usb mounted too hdd and all is ok
- Bh based on orginal image
- OBh based on OE-A an he is near to yur image in old box.
Ok. I tried the latest blackhole image and i did not get any sound on channels with ac3 5.1 and no subs.
On openatv i got sound but no subs.
What image do you recommend? :)
Sry bad English
Sry bad English
You have in AC# down mix ON or OFF ?
You go to menu and you try setup this whot you whont i menu subtiles ?
worst box i ever had, cant handle subtitles and pixels going craxy sometimes, buying a dreambox instead
Box is good but like all nead smoll setup.
Subtiles you setup in menu [ prefer language, version dvb or ttx .etc ] and mast work.
Picture is ok too.
You write about have in past OpenAtv; this image to VU+ compiled too.
try openatv or obh
