EnF70
If you are bothered by the high CPU usage in BH 2.1.1 while transcoding and streaming you can try this file. Install manually by replacing the existing file "/usr/bin/transtreamproxy".
I don't have any contacts in the Vu+ dev team, if you know someone PM me so I can send them the fix.
(patch file containing the fix is attached).
