Fix: Iplayer & itv player catchup
james81
Got this fix from the xbmc wiki
Put the attached file in folder
/usr/share/xbmc/system
Fix uses e2 player for all the catch-up content.
The file needs to be file extension .xml
Had to upload it as .xml.txt due to site rules - so it needs changed back after download.
Thanks buddy but it didn't help much. I think this xml file is for other boxes with slightly different file structure than xbmc for e2.
No thats the .xml file from my box, duo2 beta 2 image, all i did was edit it and save it, all catch up works for me no.. Need to make sure you remove the .txt for it too work
Yes. I did remove the .txt from the extention. Perhaps the reason is that my box is solo2.
OK. Thanks. Catch-up content works smoothly with this fix but the box crashes when choosing Live-TV. I wonder why!?
