Flash temp gauge
Glamring
Hi,
when i go into the BH Blue panel and select info (yellow button), the flash temperature dial is high in yellow and bordering into red lining. What does this mean and how can I fix it please?
Thanks for your support in advance.
Don't think that's the flash temp gauge your looking at, think its the flash capacity, I.e. you have not got much flash space free.
Don't think its a problem it being nearly full, just if you want to install more stuff.
Do a search on here for universes as a way of expanding your flash.
Also are your picons and epg installed in flash or on a USB?
Sent from my HTC Sensation Z710e using Tapatalk 2
