Former Miscellaneous tuner options
AlexWilMac
Moderator
In OBH 4.1.022 there still were two options (the first two) in the Miscellaneous section, the ones attached.
Afterwards, in the last 4.1.xxx and in 4.2. they (apparently) disappeared: were they moved somewhere else or replaced by other settings?
Sorry: I forgot to attach in the previous post, the screen I mentioned.
The options are still there, but as your Vu+ box doesn't have the the required files in /proc/stb/frontend the options don't show up.
They are not needed anyway, as iirc Vu+ boxes now leave the lnb powered on, when the box is in standby anyway and you can set the toneburt in the tuner setup menu.
