Freeze when switching to dvb-t
Finbarr Brady
Hi there,
Sometimes (about 1 in 20 times on average), when I switch from a satellite channel to a DVB-t channel on my Vu Duo, the whole box freezes up. This is using a Sony PlayTV usb tuner.
I can see the following in /var/log/messages
CPU 1 Unable to handle kernel paging request at virtual address 0000001b, epc == c08a2da0, ra == c08a2d94
Oops[#1]:
Cpu 1
$ 0  : 00000000 10008b00 00000002 00000020
$ 4  : 86af0104 85821a58 00000000 c0bfdaa8
$ 8  : 00000002 00000000 00000000 00001fff
$12  : 12c00000 00000000 00000000 00000000
$16  : 86af0000 00000002 00000000 85821a48
$20  : c0d1cd94 00000000 00000000 73160ea0
$24  : 00000000 8029e0e0
$28  : 85820000 85821a30 00000000 c08a2d94
Hi    : 00000000
Lo    : 00000000
epc  : c08a2da0 NEXUS_Recpump_AddPidChannel_impl+0x80/0x244 [dvb_bcm7335]
    Tainted: P
ra    : c08a2d94 NEXUS_Recpump_AddPidChannel_impl+0x74/0x244 [dvb_bcm7335]
Status: 10008b03    KERNEL EXL IE
Cause : 80800008
BadVA : 0000001b
PrId  : 0002a044 (Brcm4380)
Modules linked in: dvb_usb_dib0700 dib7000p dib0090 dib7000m dib0070 dib8000 dib9000 mt2266 tuner_xc2028 dib3000mc mxl5007t xc5000 s5h1411 mt2060 lgdt3305 xc4000 dibx000_common ipv6 brcmfb dvb_bcm7335(P) procmk
Process enigma2 (pid: 10461, threadinfo=85820000, task=88ef6550, tls=77fec490)
Stack : 00000000 8847188c 00000001 00000000 00000000 00000001 00000002 00000000
        00000000 00001fff 00000000 80022104 88471888 00000000 c0bee940 c0d0b750
        c0d1cd94 00000000 00000000 80022104 88590f00 884f9e80 800220c4 c07ab4fc
        00000000 00000000 10008b01 00000001 86af0890 86af0890 86af0890 c08a26cc
        00000000 00000000 00000000 000005e0 00000004 86af0000 c08a2684 00000000
Call Trace:
[<c08a2da0>] NEXUS_Recpump_AddPidChannel_impl+0x80/0x244 [dvb_bcm7335]
[<c0787064>] NEXUS_Recpump_AddPidChannel+0x38/0x58 [dvb_bcm7335]
[<c074bbdc>] bcm7335_recpump_start_pidchannel+0x2e0/0x3ac [dvb_bcm7335]
[<c074d0cc>] bcm7335_demux_vtuner_start_feed+0x3fc/0x420 [dvb_bcm7335]
[<c074d194>] bcm7335_demux_start_feed+0xa4/0x5c0 [dvb_bcm7335]
[<803cd724>] dmx_ts_feed_start_filtering+0x60/0x11c
[<803c9bf8>] dvb_dmxdev_start_feed+0xd8/0x15c
[<803cbe84>] dvb_demux_do_ioctl+0x5b8/0x608
[<803c9968>] dvb_usercopy+0x88/0x210
[<800d11b8>] do_vfs_ioctl+0xa4/0x6b0
[<800d1808>] sys_ioctl+0x44/0x8c
[<8000e41c>] stack_done+0x20/0x40
Code: 8e620000  50400008  92620004 <08228b81> 9242001b  26310001  5623ffef  8c440070  08228bd1
---[ end trace 6993c5f83141d178 ]---
bcm7335: hotplug_callback():
Hotplug - status.connected 0
Hotplug - Disconnecting HDMI from display
Hotplug - status.connected 1
Hotplug - connecting HDMI to display 0xe
Note that I am running the latest OpenVIX (I hope it's ok to post here about VIX!), and have installed dib0700 driver from feeds.
Any info on this would be appreciated. Thanks a million.
Hi there,
Oops[#1]:
Cpu 1
Hi    : 00000000
Lo    : 00000000
    Tainted: P
Cause : 80800008
BadVA : 0000001b
Call Trace:
Ask on Vix Board. This is the Black Hole Team Board. If you need support for your problem, first install BH image and retry with your DVB-T USB tuner.
