Frequency problem : BTsport Espn 28e astra
nazih
hi
i installed the latest bouquets with latest frequencys using DreamboxEdit , and all channel works great just btsport Hd 1 and 2 and Espn are black with 0 signal even the frequency are exactly how should be ...
Please can anyone send me some new bouquests like Vhannival or any other uploader ... and what i can do to fix the channels to works again , i have VU+ solo original
Thank you
hi
Thank you
you need auto bouquet plugin
You need to ftp the auto bouquet file into the /tmp folder then on remote press green then yellow, Then manually install ipk packages
After reboot go to menu-plugins and find auto bouquet, while in that press menu button to setup your local area, press green to ok then green again to start. Select yes to a NIT scan and let it go through the process and bingo all channels sorted
Any problems just pm me
hi
with wich softwear i insert ftp auto bouquet into /tmp folder ? i have dreamboxedit and flashfxp ? how i do it ? :(
plz here is my skype add me ... and see if you can log and help me
skype name : nbj.int.trading.company
Vhannibal motor settings are available on BH server mate. Press green button>yellow button >addons download manager>black hole settings. Last updated 25th Oct on server
hi
You could use, DCC to transfer files
* * * Dreambox Control Center * * * DCC * * *
PC:
Install DCC-E2 v1.50 ( dcce2_150.zip )
Run DCC
( Setup your connection )
( ** Test your connection **)
use "ftp" to transfer your files (Vu+ <-> PC)
Best regards
A complete Novice here. Set up my Vu Solo2 SE box. All working fine apart from setanta and BT sport.....the channels come on and are ok for about 15-20 seconds then freeze, any suggestions??
Your STB " Vu Solo2 SE ", is not an original VUPLUS STB.
So please, read the forum rules --> http://www.vuplus-community.net/rules.html
More: It´s not tolerated by forum rules, any discussion about emulators, cs, encryption, etc ... point n. 4 of forum rules.
Clones are not welcomo here. For support buy an ORIGINAL VUPLUS STB.
