From OpenPli to BH
mini
Hello to all,
I just bought a VU+solo with OpenPli. My first question is will i be able to get help from this forum or is it just for BH users?
Secondly if I want to change image to BH is there a step by step guide somewhere to use?
PS1: Box is already setup with bouqetes and don't want to lose anything
PS2: Complete newbe, so when I say step by step I mean help for "dummies"
Thanking you in advance for your help
This is a support forum for BH but you can also find users that are using OpenPli so try to ask...
You must search in the correct section (here for example) and find the guide to install BH (is very simple).
There's no way to convert an image into another so you must install BH and then reinstall your bouquets, plugins, etc. but you can save your channels list and then reload into new image.
You can also find channels list ready for upload. ;)
Have been trying to connect to vu+solo via telnet but I can't. I get the following:
openpli 3.0 android
android login:
password:
I enter <root> for login and leave pswd blanc. I get <Login incorrect>
Any idea anyone? Thank you
