AlexWilMac
Moderator
I've googled a lot to find a way to force fsck on main hdd/ssd but I'm not sure over the solution suggested because you have no sign of anything.
Someone says you have to create an empty file named forcefsck in root.
Is it right?
And, if so, which devices will it check for?
After boot the main device (the one which stores records) is /dev/sda1 but how can I pass this parameter to fsck command the way it is described above?
It seems better to launch a specific script but how exactly?
Is it right?
