... ftp stops working...
MSNBC
On a regular basis ftp stops working - in this case the Android App can't connect either.
However I can still work using the WebIF.
A reboot is helpful to fix the problem.
Solo², BH 2.1.2, network options are fine (no DHCP, manual address setting, Gateway & DNS = Router)
There are problems not only with the input via FTP. But also SSH and Telnet. Rebooting does not always help.
This can be a RAM issue.
Create and enable SWAP file.
We are investigating about these issues
File is created and enabled. These actions were done in the first place.
I read recommendations for installation. :)
I'll try to recreate and re-enable.
Thank's.
