ftps client
pepe.juarez
Dear Community,
I would like to download via ftps some files from a server to my receiver, for this reason I would like to know if there is a ftps client included in the BH image. I was using the forum search functionality but the only thing I found was related about use the FTP Panel (FTP server).
So is there a ftps client? an option B might be a sftp client... it would be perfect if there would be a "download manager" with GUI that allows all these protocols...
Best regards.
Black Hole uses ftp daemon common integrated in enigma2 - vsftpd. Why precisely sftp is needed?
Hi Vytenis,
Yes, that's correct, vsftpd makes the receiver to work as a FTP server. However what I would like is to use the receiver as a FTP client (using encrypted protocols).
I found a plugin called FTPBrowser but it is not compatible with FTPS or SFTP, therefore is not useful for me :(
Any other option?
