Full Backup -> Box setup cloning?
Nixy82
Hi
Can I use the full back up feature to clone my box's set-up onto a new unit?
My friend is keen to get one and I'm wondering if I can use the full back up feature (then USB in the front, power up restore) to clone my existing box to cut down the set-up time on a fresh one.
When you will be can in future change your setup from old image to new image good way is used personal backup.
Becouse after run new image on box you mast only restore personal bakup and you will bw have old setup in new image.
That's really cool
So for upgrading, do a personal back up first...then update the image...the restore the personal backup and all the settings, plug ins etc on the new image will be the same as the old.
Nice feature!
That's really cool
Nice feature!
Yes and this backup is amde on HDD this gived possibility never deleted backup when you change image.
In my box im used only person backup this is best option when you change image big number time.
