ghost channels
ljupces
Vu+Duo2 - two simple s2 tuners with loop,one lnb.Some channels operate normally and after scrolling does not work, it is still in the list,EPG work but signal meter shows null. After restarting only work once if the channel has remained the same, again disappear after scrolling.Settings are vhannibal e2 motor.On other settings- same problem on different chanels.With other firmware similar problem.All other things are working perfectly.
First -advanced,second is not important still i have only one active lnb output.
Why advanced?
Try to set the tuner in this way:
Configuration Mode: Simple
Mode: Single
Satellite: Your sat...
Send DiSEqC: No
Settings are vhannibal e2 motor,DiSEqC: 1.2,parabolic antena 1,8m;LNB dual Invacom but one cable at this moment.That is the reason.
