I have a Vu+ Duo2 with Black Hole image, that always (24/7) recording something without being in the timer-list. It is annoying as it always uses tuner B.
How can i fix this problem?
Yes i have, but it is only i that know the output port. And it shows the same when the devices have been connected is off. Will try to change the port.
