Green screen in all options with BH 2.1.4
fuckplus
Hello
I install the last Black Hole 2.1.4 with meoboot and now don´t work nothing.
If I go to options to "Factory Reset" there is green screen, if I go to load from usb for install other blackhole there is green screen, now my ip login from filezilla don´t work.
How can delete this corrupt image for install previous 2.1.2 image?
Best regards
If you talking about image in flash you don't have to delete anything just flash new image same way you installed before via usb if talking about the image in meoboot just move down to image you want to delete and press yellow button and press ok job done
