GSD impossible to avoid
AlexWilMac
Moderator
Hello,
my STB, all of a sudden, started getting into a unstoppable sequence of GSDs. I simply cannot do anything and I have just a few seconds to read it: it seems that the culprit is Multiquickbutton, although I've been using it for some days now.
The problem is: I cannot delete the plugin because the STB doesn't finish the boot.
I cannot have access by FTP for the same reason. What can I do? Except for reflashing the STB, it seems that the only solution is taking the HDD off the box and delete the plugin folder. But I'm not sure that this is a good idea: is this the same than uninstalling using STB functions?
Before all this started I got a message that the HDD was full (it's almost empty!) or that the recording path was read-only (and actually I wasn't able to record any event). So I created a new folder and everything seemed to be OK, although I could understand why, without any changes in the HDD settings or folders, all of this started...
The problem is worse than expected: also reflashing with BH 2.1.4. the process doesn't complete and the identical GSD restart. Maybe it's the FS? I could only che under linux or maybe my Mac where I added the ext2 and ext3 fs... Bad situation for me who am quite new at VU+....
