Hello, almost everytime when I am starting mediaplayer, BH hangs and I must restart the tuner with off/on power supply, maybe there is a way to fix this problem?
After fresh boot system working ok.
it's a spinneronly the "loading" circle on the TV top left corner.
And no changes untill pressing OFF/ON power supply.
Soory, I am not very good IT specialistit's a spinner![]()
You don't have to leave your sofa anymore while rebooting your boxThanks for advice with power button restart trick![]()
In may post im was think about my duo if im no have setup swap my box have problem like write bakenonas he start work very slow and im mast wait to acces to my films on hdd.My SWAP is located on Hard Disk and its size is 256. What a difference between HD or USB for SWAP location?
If Duo2 has 2GB of RAM do you think there is not enough of free memory left?
