hard drive loss
paulrx
can anybody help i have a duo and an ultimo after a power down or restart i lose the hard drives and have to initialise black hole 2.0.o running on duo i think its the same for the ulitmo.
Maybe there is a fault with the HDD. I don't have this problem on Uno and Duo.
Sent from my Nexus 4 using Tapatalk 2
Happend to me many times..some times rebooting solved..but other times, lost everything..
Sent from my HTC One X using Tapatalk 2
Please, upgrade to BH 2.0.1 and next do an online update to rev. A.
I have now sorted with the updates on my ultimo just need to do the same on the duo the drives are new wd red 1tb I use these because they should be more reliable they are used in nas systems. and also they almost silent
They are 7200 rpm. Aren't they noisy?
